EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
JohnT_Altera
6 years agoHi,
May I know if you are able to create a design using "Serial Flash Controller" IP? I suspect that the EPCQ device that you are using is having block protection enabled which cause the erase or programming not to work correctly.
