EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
EFran7
6 years agoHi,
I'm able to perform full erase and blank check.
The result is OK.
Attached is the file downloaded from EPCQ128 using Quartus Programmer after full erase.
This file is identical to programmed jic except for the final part which is different.
However, the FPGA configuration does not work.
