EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
JohnT_Altera
6 years agoHi,
May I know if all 50 device is not working? Could you provide me the jic file that you use to program the flash and also performed read back data from flash to me?
