EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
JohnT_Altera
6 years agoHi,
I observed that EPCQ128N is working and not working. Not sure if what is the different. Not sure if you are able to provide the full part number of the EPCQ128N? Are you using the EPCQ-A device which is not working?
