EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
EFran7
6 years agoHi,
If I replace the EPCQ memory with another using the same jic file, the FPGA configuration works well.
The memory that works has the following marker:
EPCQ128N
G0OO4 VS
CHN244
Thanks!
