EFran7
6 years agoEPCQ128N not works correctly
Goodmorning everyone, i have a problem on a card mounting an FPGA CycloneV. The FPGA is connected to an EPCQ128N memory in active serial mode. If I compile the FW by correctly setting all pin opti...
JohnT_Altera
6 years agoHi,
May I know if this issue is related to Nios II firmware or FPGA configuration issue? Could you provide me the full part number?
