12 years ago
Entities work in individual projects but not in single project together.
Hello every one
I have created multiple entities, that work individually in individual projects, but when I combine all the entities in to a single project some entities stop functioning. When I compile and run the project with multiple entities on my DE1 cyclone 2 board, entities take chances not working, but sometimes all of them work but when I compile again without changing any thing in particular it doesn't work ect.
More detailed:
I coded in VHDL an audio player, music saved on the SD card, that can be controlled through the RS232 communication board - works perfectly in own project.
I also coded in VHDL a temperature display, that uses the 4 7 segments on the development board, that "looks up" a 8 bit value, that is generated by the switches, and outputs the corresponding values for the 7 segments. This part also works perfectly in its own project. But as soon as I combine these in one project one or the other or sometimes even both stop working.
I only use 10% of the logic elements and 2 % of the ram (when no signal tapping is implemented)
if some one has any idea what the solution to my problem is, please comment.
Arno (student at the University of Pretoria)
    Do you have testbenches for all of them? Have you done a system test for all of them together? Are all designs synchronous?
    Both entities work independently on the cyclone 2 DE1 development board, so there is no reason to make test benches for them?
    I am not sure what you mean with system test. The 2 entities are not synchronous.
    You would make a testbench so that you could test any situation without having to revert to the board - debugging on hardware is a pain in the backside. And system test I mean I testbench that instatiates your two entities.
    And With your 2 blocks not synchronous - good luck dubugging it - it could be all sorts of things..
