12 years ago
end of a loop
hi my friends,
this is my code:
i want to change the value of "loop_ends" at the end of loopS.but at the end, it never becomes '1' .
what should i do ?
    L1:for s in 0  to NSTAGES-1 generate
        L2:for t in 0 to 2**s-1 generate
            begin
            DUT: entity work.mux
            port map (
                clk        => clk,
                data      => n(input_index_end downto  input_index_start),
                input     => n(output_index),
                output   => m(output_index)
                end generate;
    loop_ends<='1' when s=NSTAGES-1 else '0';
    end generate;
    Why would you want this?
    A for-generate expands in place (instantiates a series of components) not in time.
    --- Quote Start ---
    --- Quote End ---
    i wanna found when output of loops is prepare,
    when "loop_end" become '1' i found i can use the output!
    josyb already anwered you.
    VHDL generate loops are NOT sequential instruction loops in the sense of a common software programming language.
    Loops simply instantiate the array of components you specified; this way you don't need to write manually the single stages.
    So the output is immediately ready, apart any delay caused by the actual logic function you implemented.
