16 years agoencrypted+compressed .tff with quartus_cpf command line
Context :
Device Stratix3 - EP3SL200F1517 (+encryption) QuartusII 9.2 Convert Programming File - graphic interface I need to generate an encryted+compressed .ttf file with the command line "quartus_cpf", instead of using Convert Programming File graphical interface. I use the following command : quartus_cpf -c --option=<option file> --key <keyfile>:<keyid1>:<keyid2> <input_sof_file> <output_ttf_file> with option file contenu : compression=on The .ttf is generated, functionnal (and well encrypted) :) , but NOT compressed :mad: . I have tried also this syntax (same resuts) : quartus_cpf -c --key <keyfile>:<keyid1>:<keyid2> <input_sof_file> <output_ttf_file> -o <option file> Rq : the option file (.txt file) is recognized (because error if renamed or suppressed), but the contenu seems to be ignored (no error if contenu = "compresion=on" or "toto") :cool: . The encryption+compression is correctly done using Convert Programming File :) , but we really need to do it in command line... Thanks for your help. Catherine
