8 years agoEncoder for dsd audio stream in SDIF-3 format, VHDL - help a newbie
Hello folks, I'm a newbie in VHDL programming. I'm trying to achieve SDIF-3 encoding from a dsd datastream coming off from an A-D conversion chip. The dsd stream from the chip features two...
8 years agoThank you for the quick reply.
Unfortunately my code cannot be synthesized. I get the following error: "[Synth 8-27] nested clocked statements not supported [encoder1.vhd":27] What I wanted to get was: at rising edge, the first semi-bit of pattern, at the falling edge, the second semi-bit (inverted) of pAttern. Is there a better way to do it? If you can help, that would be fantastic. My code is attached to my first message. Thanks.
