12 years ago
Enabling Schmitt Triggers for MAX V in Quartus
[SOLVED]
Hello everyone,
I have recently gotten into programmable logic, and intend to use a MAX V CPLD (5M570ZT100C5N) in one of my projects, specifically for processing some quadrature encoder inputs.
Part of the noise-filtering circuitry requires the use of Schmitt-triggers, and I saw that the MAX V has built-in schmitt-triggers on the I/O pins.
I am just wondering how you enable these schmitt-triggers in Quartus II.
Thanks in advance,
BuildaMachine
EDIT: It is very simple, just change the I/O standard in the pin planner
On a side note, what is the difference between the CPLDs of the same family with the different suffixes (e.g. C4, C5 C5N)?
    C/I/A indicates the temperature range: Commercial, Industrial, Automotive
    4/5 indicates the speed grade (lower is faster)
    N indicates lead free
