13 years agoEnable open drain on CRC_ERROR pin
I try to use the CRC_ERROR pin on a Cyclone IV device.
The functionality is however not clear. According to the documentation this pin is open drain. According to Quartus the open drain is selectable. Question: Does the selection:1/ Enable Error Detection CRC also enable the CRC_ERROR pin? Or does the selection:2/ Enable open drain on CRC_ERROR pin enable this pin? If selection 2/ is correct, then the text should read: Enable CRC_ERROR pin (open drain) Thanks for any answer.
