11 years ago
Emulate OpenCL Kernel on windows - 'env' is not found
I am running the emulation of hello_world example under windows 64bit. While I can't find "env". Is that a binary executable file of Altera opencl sdk or a generated file from previous steps?
In details: I managed successfully to execute the command "aoc -v -march=emulator hello_world.cl", After that, I compiled the hello_world host program with Visual Studio.
But, when I try to run the command "env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=s5_ref hello_world", I get the following error message:
'env' is not recognized as an internal or external command, operable program or batch file.
Could you help me to find a solution to this problem?
Thanks and Regards,
Michael
    --- Quote Start ---
    --- Quote End ---
    You have to add CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref to your environment variables and then run .exe file (without any additional commands).
    --- Quote Start ---
    --- Quote End ---
    Hi Chris,
    It works. I added CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref to my environment variables, and run the hello_world.exe (with the hello_world.aocx in the same directory, and WDAPI1021.dll/altera_s5_ref_mmd.dll in windows/system32).
    Thank you so much for the help. If you think there is better ideas to deal with the .dll please also kindly let me know.
    Michael
