CosmoKramer
3 years agoemif ref clock constraint
clk_a is available on a pin on the fpga. This is input to EMIF IP as its ref_clk. This also goes to bunch of other logic on the fabric. I have a create_clock command for clk_a: create_clock -name ...
AdzimZM_Altera
3 years agoHello,
I'm not really sure about that but can you share the design file that I can replicate it at my end?
I can try to check if there is any cause for the EMIF IP to not state the ref_clk as a master clock.
You can send it through Private Message if you're not comfortable to share it in this public forum.
Adzim
