CosmoKramer
3 years agoemif ref clock constraint
clk_a is available on a pin on the fpga. This is input to EMIF IP as its ref_clk. This also goes to bunch of other logic on the fabric. I have a create_clock command for clk_a: create_clock -name ...
AdzimZM_Altera
3 years agoHi,
Does the emif_usr_clk is exported or connect to any other clock input port?
Can you share some snapshot of the SDC File Lists and Clocks from the Timing Analyzer GUI?
Adzim
CosmoKramer
3 years agonope. emif_usr_clk should be generated within the emif ip. I see all the generated clocks from the ip are in the "ignored sdc assignments" list. I have two instances of this ip. Does that cause any issues? it is ignored list because "ip did not find a master clock though it thinks ref_clk as potential master clock". Any reason why tool did not use ref_clk as master clock?
