CosmoKramer
3 years agoemif ref clock constraint
clk_a is available on a pin on the fpga. This is input to EMIF IP as its ref_clk. This also goes to bunch of other logic on the fabric. I have a create_clock command for clk_a: create_clock -name ...
sstrell
3 years agoJust create a clock constraint for user_clk_a as usual. You can use the Name Finder in the timing analyzer GUI to find the correct target. Then use create_clock_group as usual.
