Altera_ForumHonored Contributor13 years agoEdge detection VHDL (what's the best solution) Hello everybody Well for Edge detection we always use C language because it's much easier to code the algorithm !! What do you think is the best solution that can be coded in VHDL for edg...Show More
Altera_ForumHonored Contributor13 years agoI suggest the same as ^ matlab to model/sim before you get to the VHDL
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
