13 years agoHi,
do you talk on detecting an external signal rising or falling edge (e.g. an HW-Switch "pressed" detection or a encoder's output)? In either case you should synchronise the external signal to your's system clock (twice to prevent metastability issues). Additionally I would suggest to implement a debouncing (especially when talking on HW-Switches...) by using a simple counter to ensure the external signal is stable for xyz clock cycles. This counter could also be used as the edge dectector. Just as a Quick'n dirty implementation: synchronise external signal to system clock (twice) when '0' => counter reset, when '1' => counter increments until a) external signal gets '0' again (reset) (i.e. signal was bouncing) or b) signals was stable '1' for xyz cylces (no bouncing and rising edge detected). (not to mention you could use the external signal directly for asynchronous detection by "if rising_edge(ext_Signal) then..." but be aware with asynchronous logic and not debounced signals) Best regards, Carlhermann
