9 years agoEdge detection asynchronous signal fails
Hello, I am working on a fairly simple VHDL design where I am trying to detect the rising_edge of an input. Whenever a rising_edge is detected I want to multiply another input by 2 and output ...
9 years agoThanks both for your replies. I changed my code (see below) so it works on a rising_edge of a clock input and also removed the else statement since I got glitches on my_output. Seems like my_output was changed to quick. It works now
A follow up question to @Tricky comment: how do concurrent statements outside a process work then? Don't say also assume that the values are ready from 0s? e.g.my_output <= '111111111' when data_ready = '1'; Or would i use the after statement here? Changed code of the original question:(working now): entity mul is port(
clk : in std_logic;
my_input : in std_logic_vector( 7 downto 0 );
data_ready : in std_logic;
my_output : out std_logic_vector( 8 downto 0 )
end mul;
architecture behavior of mul is
signal previous_value : std_logic := '0';
begin
mul_2 : process( clk )
begin
if rising_edge( clk ) then
previous_value <= data_ready; -- set previous value
if data_ready = '1' AND previous_value = '0' then -- detect rising edge
my_output <= my_input(7 downto 0) & "0"; -- mul by 2, shift left
end if;
end if;
end process;
end behavior; Testbench:
BEGIN
-- code that executes only once
data_ready <= '0';
my_input <= "11100011"; -- expected output 111000110
wait for 200ns;
data_ready <= '1';
wait for 200ns;
data_ready <= '0';
my_input <= "00110011";
wait for 200ns;
data_ready <= '1';
wait for 200ns;
WAIT;
END PROCESS init;
-- clock generation - 50MHz
process
begin
clk <= '1';
wait for 10 ns;
clk <= '0';
wait for 10 ns;
end process; Cheers and thanks.
