14 years agoSorry to dig this post back up, but it's the only one that shows with a Web search. Simply having the path to Modelsim set in Quartus II is not enough. In order to fix this problem, you have to go to your project properties, select "EDA Tool Settings" in the left-hand pane, and pick the simulator of your choice (e.g. Modelsim) for the "Simulation" setting.
