13 years ago
Dynamic width of inputs in VHDL.
Hi, I'm finishing my final year project and while connecting a lot of components together I ran into a problem I missed while writing the first component.
I would want to dynamically change the width of my std_logic_vector inputs or a least create signals that have dynamic width depending on an inputed natural, example:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test1111 is
port(
n: in natural
end test1111;
architecture archtest of test1111 is
signal lk:std_logic_vector(n downto 0);
begin
end archtest;
In this example I have to following problems: the signal lk gives the error: expression is not constant vhdl., does this mean that signals in vhdl HAVE to have constant widths?
I got the same problem when declaring a function:
function main (poly_in00:std_logic_vector ; n,k: natural) RETURN std_logic_vector is
variable vPoly : std_logic_vector(n downto 0) := (others => '0');
Now, normally I would use the 'length parameter in a function, but in this case I have a 2000 wide std_logic_vector but only need a part of it(n) for calculations
It would be awesome if anyone could help, thanks a lot!
Fred
    If n is static per simulation run, then use a generic.
    If n needs to change during the simulation, then either dynamically create the std_logic_vector, or use a vector with a width that is the maximum value for n. In that case, use a subtype for port n that restricts the values for n, eg., subtype n_t is natural range 0 to 2000.
    Cheers,
    Dave
    Hm, I seem to still have the same problem, I declared n_t is natural range 0 to 2000 in a library
    ENTITY logic IS
    PORT( clock, reset, readyfsmtologic: IN STD_logic;
    n,k: in n_t;
    datafsmtologic : in std_logic_vector(63 downto 0);
    datalogictofsm : out std_logic_vector(63 downto 0);
    donelogictofsm : out std_logic
    END logic;
    FUNCTION main (poly_in00:std_logic_vector ; nf, kf: n_t) RETURN std_logic_vector is
    variable out:std_logic_vector(2*nf + 1 downto 0):=(others=>'0');
    begin
    --function
    end
    It says that the line
    Error (10779): VHDL error at logic.vhd(118): expression is not constant
    Fred
    Rather than posting code snippets, could you post a zip file with a minimal set of files.
    Note, try not to use reserved keywords in your code, otherwise you will get weird errors - 'out' is a keyword.
    I don't think that is your error, but its a good thing to keep in mind.
    Cheers,
    Dave
    You cannot dynamically resize signals while a simulation is running. They have to be fixed size during a run, so you will have to go with the generic suggestion and make the size of the vector the worst case size. Think about it- trying to resize a signal is like trying to add more wires to a circuit while it is switched on, which is physically impossible.
    The only way you can "dynamically" change an array size is with a pointer type, but you cannot synthesise them and are for testbenching only.
