15 years agoDynamic delay for LVDS inputs on a Cyclone 3
I have to implement an interface to a sensor chip that delivers its data on several (more than 8) LVDS lines in DDR mode along with an LVDS clock. == Details to the situation == The lines have different phase delays and so I have a hard time to sample all lines correctly. The sensor manufacturer explains the handling in a 2 stage training sequence: * Set the sensor to test mode (where it repeats a static pattern) * first find the right phase for the data bits by shifting the delay until the sampled data changes and take the middle between two setting where it changes * second use bit-slipping until the shiftregisters show the right value The explanation is for Xilinx' Virtex IV devices which seem to have the ability to do the first part without bigger problem - we however are using a Cyclone3 chip and I _have_ bigger problems doing it... == Already thought about == * I've thought about using a separate sample clock for every channel * I would use up at least 2 PLLs for the solution (that I don't have spare...) * If I would use dual clock FiFos to do the clock crossing I would loose the context between the LVDS channels * Timequest can handle input delays but only statically. In the end a delay element with a fixed delay is instantiated. == The real question == I thought, I could implement a structure as in the picture after the diff_input and before the double data rate sampling block. * The single-ended signal is here fed in at four different places * It has to pass either 2 or 4 or 6 or 8 gates * the Delay register which contains only one '1' chooses which path is put out on the output * You could place many more of these and-or structs in if the delay isn't big enough input_delay.gif * Do you think, this could work? * Will the fitter try to make all paths synchronous again - one of the things I fear? * Can I use Timequest to *** make my plans clear (to the fitter)? *** analyse if it works? * The data is coming in with 200MHz DDR - is a little bit logic like some "and"s and "or"s able to insert enough delay for 2.5ns delay (max) Thanks for your patience reading all this. I hope, I haven't forgotten the important parts and you have gotten a clear view of the problem. Since I haven't found any usable information to this topic yet, I'm curious to see if there is a good way of doing this. The sketched solution might be totally bogus - If you feel like it, please tell me so. And if you know a good / better way of realizing an dynamic delay I'm happy to abandon this strange and-or-scheme. Best regards, Roman
