15 years ago
Dynamic delay for LVDS inputs on a Cyclone 3
I have to implement an interface to a sensor chip that delivers its data
on several (more than 8) LVDS lines in DDR mode along with an LVDS clock.
== Details to the situation ==
The lines have different phase delays and so I have a hard time to sample
all lines correctly.
The sensor manufacturer explains the handling in a 2 stage training sequence:
* Set the sensor to test mode (where it repeats a static pattern)
* first find the right phase for the data bits by shifting the delay until the sampled data changes and take the middle between two setting where it changes
* second use bit-slipping until the shiftregisters show the right value
The explanation is for Xilinx' Virtex IV devices which seem to have the ability to do the first part without bigger problem - we however are using a Cyclone3 chip and I _have_ bigger problems doing it...
== Already thought about ==
* I've thought about using a separate sample clock for every channel
* I would use up at least 2 PLLs for the solution (that I don't have spare...)
* If I would use dual clock FiFos to do the clock crossing I would loose the context between the LVDS channels
* Timequest can handle input delays but only statically. In the end a delay element with a fixed delay is instantiated.
== The real question ==
I thought, I could implement a structure as in the picture after the diff_input and before the double data rate sampling block.
* The single-ended signal is here fed in at four different places
* It has to pass either 2 or 4 or 6 or 8 gates
* the Delay register which contains only one '1' chooses which path is put out on the output
* You could place many more of these and-or structs in if the delay isn't big enough
* Do you think, this could work?
* Will the fitter try to make all paths synchronous again - one of the things I fear?
* Can I use Timequest to
*** make my plans clear (to the fitter)?
*** analyse if it works?
* The data is coming in with 200MHz DDR - is a little bit logic like some "and"s and "or"s able to insert enough delay for 2.5ns delay (max)
Thanks for your patience reading all this.
I hope, I haven't forgotten the important parts and you have gotten a clear view of the problem.
Since I haven't found any usable information to this topic yet, I'm curious to see if there is a good way of doing this.
The sketched solution might be totally bogus - If you feel like it, please tell me so.
And if you know a good / better way of realizing an dynamic delay I'm happy to abandon this strange and-or-scheme.
Roman
    I didn't tell about a datasheet parameter. It's a typical and average value, comprised of LUT and routing delay. You'll find individual "micro-timing" parameters in the device handbooks and delay estimation in timing analysis.
    But as already stated, the logic cell delay is also depending on PVT variations, a rnage of about 1:2 can be expected. Thus I wonder, what kind of specification you are looking for?
