15 years ago
Duty cycle VHDL
Hello!
I'm trying to create an A and B pulse and change the duty cycle of that pulse. The program shown below just changes the frequency and creates an A and B pulse, but I'm not able to change the duty cycle.
Has anyone a tip or idea??
library ieee;
use ieee.std_logic_1164.all;
entity freq is
port(
clk :in std_logic;
rst :in std_logic;
S0 :in std_logic;
out_0 :out std_logic;
out_1 :out std_logic
end freq;
architecture Behavioral of freq is
signal cnt : integer;
signal temp : std_logic;
signal temp_out : std_logic;
begin
--XXXXXXXXXXXXXXXXXXXXXXXXXXXX
--CLOCK
process(clk)
begin
if(rst='1') then
temp <= '0';
cnt <= 0;
elsif(clk'event and clk='1') then
if(cnt= 1000000) then
temp <= not temp;
cnt <= 0;
else
cnt <= cnt +1 ;
end if;
end if;
--Switch
if (S0='1') then
temp_out <= temp;
else
temp_out <= '0';
end if;
end process;
out_0 <= temp_out;
out_1 <= not temp_out;
end Behavioral;
1 Reply
    Hi Frans
    Infact your code simply creates a 50/50 square wave.
    I think this is what you need:
    library altera;
    library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.numeric_std.all;    -- for the unsigned type
    entity pwm_generator is
    	port (CLKIN   : in  std_logic;
    		  TPERIOD : in  unsigned(7 downto 0);
    		  TWIDTH  : in  unsigned(7 downto 0);
    			PWM   : out std_logic );
    end entity pwm_generator;
    architecture pwm_gen_a of pwm_generator is
    	subtype small_int is natural range 0 to 500;
    	begin
    		update: process(CLKIN) is
    		variable tcnt : small_int := 0;
    		begin
    			if rising_edge(CLKIN) then
    				tcnt := tcnt + 1;
    				if tcnt = TPERIOD then
    					tcnt := 0;
    				end if;
    				if tcnt >= TWIDTH then
    					PWM <= '0';
    				else
    					PWM <= '1';
    				end if;
    			end if;
    		end process;
    	end architecture pwm_gen_a;
    You may need to change TPERIOD and TWIDTH bit length to meet your specs.
    You must also add the pwm switching function.
