According to the word document you should not declare clock and resets as vector because are the same clock and reset for all instantiated modules. It's the same wire. But Ser_out and ser_in must be vector. Something like:
signal ser_in1 : std_logic_vector(1 downto 0);
signal ser_out : std_logic_vector(1 downto 0);
signal lock_out : std_logic_vector(1 downto 0);
Top_level_Top: for i in 1 to 2 generate
duplicate:entity work.top(Design)
port map(
clk_in1=>pll_25M_out, --in std_logic
clk_in2=>pll_100M_out, --in std_logic
ResetN_25M => ResetN_25M, --in std_logic
ResetN_100M => ResetN_100M, --in std_logic
ser_in1 => ser_in1(i - 1), --in std_logic
ser_out => ser_out(i -1), --out std_logic
lock_out => lock_out(i - 1) --out std_logic
