13 years ago
duplicate a component
I am having a problem with component duplication.
I would like to duplicate this 2 port maps in one command (loop,generate...)
I have 2 types of parametes that need an Index:
1.1bit from an std_logic_vector m0_piezo_lg_p(0)
2.a regular register (m0_hifu_hv_pw0).
Can somebody assist?
Many thanks
M0_pulser_block0: pulser
port map
clk_64m => clk_64m,
reset_n => reset_n,
piezo_p => m0_piezo_lg_p(0),
piezo_n => m0_piezo_lg_n(0),
fire_busy => m0_fire_busy(0),
fire_piezo_1clk_r => fire_piezo_1clk_r,
fire_piezo_1clk_f => fire_piezo_1clk_f,
hifu_cal_sel => hifu_cal_sel,
hifu_hv_pw => m0_hifu_hv_pw0,
cal_hv_pw => m0_cal_hv_pw0,
phase_delay => m0_phase_delay0,
stdn => stdn,
break_duration_reg => break_duration_reg
M0_pulser_block1: pulser
port map
clk_64m => clk_64m,
reset_n => reset_n,
piezo_p => m0_piezo_lg_p(1),
piezo_n => m0_piezo_lg_n(1),
fire_busy => m0_fire_busy(1),
hifu_hv_pw => m0_hifu_hv_pw1,
cal_hv_pw => m0_cal_hv_pw1,
phase_delay => m0_phase_delay1
stdn => stdn,
    You will need to declare your register as two dimensional array then apply:
    for i in 1 to 2 generate ...
    can I do something like this ?
    many thanks!!!!
    1. ARCHITECTURE
    COMPONENT pulser
    PORT
    hifu_hv_pw :in std_logic_vector ( 7 downto 0 ) --0->15 hifu_pw
    END COMPONENT;
    2.ARCHITECTURE
    type m0 is array (1 downto 0) of std_logic_vector(7 downto 0);
    signal array_pw: m0 ;
    3. BEGIN
    hifu_hv_pw0<="01010101";
    hifu_hv_pw1<="11111111";
    array_pw <= hifu_hv_pw1 & hifu_hv_pw0 ;
    4. PORT MAP
    puls : for n in 1 downto 0 generate
    pulser_port:pulser
    port map
    hifu_hv_pw => array_pw(n)
    end generate puls;
    you got the idea.
    But assign as follows:
    array_pw(1) <= "11111111";
    array_pw(0) <= "01010101";
    Many thanks for you help.
    I have one more question related to my design,
    I have another component that has lots of registers (120 registers 8bit each).
    In this case I can declare an Array in side this component.
    my quaestion is:
    can I drive it out of this component to the top level?
    I was trying to do that with no success, how should I define this output?
    ENTITY registers IS
    PORT (
    my_array :out -- .....??
    END;
    I opened a new thead relating this quastion, so nobody will be confuse.
    thanks
