15 years ago
Dual-Purpose Pins in Quartus 10.0
Hello there,
i have switched my project from Quartus 8.2 to Quartus 10.0
My Configuration scheme is Active Parallel.
(Active Serial has the same problem).
After Device configuration i want to use the configuration pins as regular IO's.
My Problem:
Under Quartus V10.0 i can not set the Dual-Purpose Pins to "Use as regular I/O".
DCLK can only set to "Use as programming pin"
Data[1]/ASDO can only set to "As input tri-stated"
Data[7..2] can only set to "As input tri-stated"
FLASH_nCE/nCSO can only set to "As input tri-stated"
Other Active Parallel pins can only set to "As input tri-stated"
Is this a Quartus 10.0 problem ?
    --- Quote Start ---
    Same here. I'm using a EP4C115F23C8 with Quartus II 10.0 SP1. As recommended, I added the following lines to the .qsf file:
    set_global_assignment -name RESERVE_FLASH_NCE_AFTER_CONFIGURATION "USE AS REGULAR IO"
    set_global_assignment -name RESERVE_DATA0_AFTER_CONFIGURATION "USE AS REGULAR IO"
    set_global_assignment -name RESERVE_DATA1_AFTER_CONFIGURATION "USE AS REGULAR IO"
    set_global_assignment -name RESERVE_DCLK_AFTER_CONFIGURATION "USE AS REGULAR IO"
    With SignalTap I can see the correct waveforms on FLASH_CE#, DCLK and ASDO, but DATA0 is always high.
    If I measure on the hardware, I see the corresponding waveforms on FLASH_CE#, ASDO and DATA0. but dclk is always high (all signals have external pull-ups). As DCLK behaves differently between SignalTap and hardware, I assume that the DCLK FPGA Pin actually is in high-impedance state.
    The Pin-Out File tells this:
    Pin Name/Usage : Location : Dir. : I/O Standard : Volt. : Bank : Usr. ***.
    Fpga_Dclk : K2 : output : 3.3-V LVCMOS : : 1 : Y
    So one could assume that everything is ok, but it obviously is not. Going back to Quartus 9.x is no option because the 9.x EPCS Flash Controller does not work with Cyclone IV devices. Any ideas around?
    --- Quote End ---
    The mistery seems to be resolved. The user design can't use the DCLK pin as an output if the Cyclone IV has been programmed in PS mode. If AS mode has been used for programming, the DCLK output works just fine with the EPCS controller. So, if using PS mode, one might consider connecting the EPCS clock signal to a user I/O instead of the DCLK pin (which actually worked in my case).
    --- Quote Start ---
    The mistery seems to be resolved...
    --- Quote End ---
    No, not resolved at all. EPCS controller remains unusable on Cyclone III.
    Tried Quartus v10.0 SP1, both 32 and 64-bit.
    Fed up with it's new "features"... :evil:
    for now back to v9.1, until maybe service pack 2, 3, ...
    Hi guys,
    For problems with the EPCS controller with Cyclone III (and IV) devices try switching to Quartus 10.1.
    I could not get any communication with the EPCS chip on my custom board from the Cyclone III with Quartus 10.0 (SP1) no matter what work-arounds I tried with those dual-purpose pins, the assignments etc.
    Being somewhat a sceptic - I ported the design back to Altera tools 7.2 and ran the Altera standard memory test on the EPCS. Worked just fine. So I took faith in one hand and a large cup of tea in the other.... and installed 10.1.
    Looks like the folk at Altera have come through with a fix.
    Now, there may be other bugs lurking under the skin of 10.1 somewhere - but my board is happily booting from flash; so I'm happy for the moment.
    Peter
