16 years ago
Dual ported ram in modelsim
I have problems accessing dual ported ram in Modelsim.
My ram looks like this:
component ram_megafunction is
port
address_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
address_b : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
clock : IN STD_LOGIC ;
data_a : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
data_b : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
rden_a : IN STD_LOGIC := '0';
rden_b : IN STD_LOGIC := '0';
wren_a : IN STD_LOGIC := '0';
wren_b : IN STD_LOGIC := '0';
q_a : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
q_b : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
end component;
when i write the following:
data_in <= "10101010101010101010101010101010";
the resulting data_out is "X0X0X0X0X0X0X0X0X0X0X0X0X0X0X0X0";
What i am doing wrong?
(Sorry for my bad english)
    It seems that you have multiple drivers on some signals. Forcing a signal to 0 and 1 at the same time will give an X.
    You can check a few things:
    - do you have only one connection on data_a and data_b?
    - are you trying to write two different values from each port at the same address?
    - do you have only one connection to data_out?
    Ok, thank you, i have found the problem.
    data_out was driven twice.
