17 years ago
Dual port RAM in Quartus II 7.2, different behavior on ModelSim than Quartus simulato
I'm using the Quartus II template for a true Dual port RAM with single clock, when I simulate it in Quartus simulator the behavior is ok, and synthsised correctly to the memory bits in a Cyclone III device.
However, when I simulate the same code using ModelSim RTL simulation the behavior is different. The problem arises when I try to write to both ports at the same time at two different addresses, where the data is written as 'X'!!. Note that: the whole memory is initially zeros.
I use the same code of the template directly from Quartus, which is attached below. Any explanation??!!
library ieee;
use ieee.std_logic_1164.all;
entity true_dual_port_ram_single_clock is
generic
DATA_WIDTH : natural := 8;
ADDR_WIDTH : natural := 6
port
clk : in std_logic;
addr_a : in natural range 0 to 2**ADDR_WIDTH - 1;
addr_b : in natural range 0 to 2**ADDR_WIDTH - 1;
data_a : in std_logic_vector((DATA_WIDTH-1) downto 0);
data_b : in std_logic_vector((DATA_WIDTH-1) downto 0);
we_a : in std_logic := '1';
we_b : in std_logic := '1';
q_a : out std_logic_vector((DATA_WIDTH -1) downto 0);
q_b : out std_logic_vector((DATA_WIDTH -1) downto 0)
end true_dual_port_ram_single_clock;
architecture rtl of true_dual_port_ram_single_clock is
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array(addr_a'high downto 0) of word_t;
-- Declare the RAM signal.
signal ram : memory_t;
begin
-- Port A
process(clk)
begin
if(rising_edge(clk)) then
if(we_a = '1') then
ram(addr_a) <= data_a;
-- Read-during-write on the same port returns NEW data
q_a <= data_a;
else
-- Read-during-write on the mixed port returns OLD data
q_a <= ram(addr_a);
end if;
end if;
end process;
-- Port B
process(clk)
begin
if(we_b = '1') then
ram(addr_b) <= data_b;
q_b <= data_b;
else
q_b <= ram(addr_b);
end if;
end if;
end process;
end rtl;
    Using the template would be fine if it weren't broken for simulation. Using the Verilog version requires me to have both a Verilog and VHDL simulation license for ModelSim, doesn't it?
    Moreover, instantiating the primitive causes simulations to run significantly slower. I'd prefer to use a configuration switch in the top level on a generic dual port RAM in VHDL than do mixed-mode HDL.
    In the end, the template should be changed to allow proper simulation in either language.
    --- Quote Start ---
    --- Quote End ---
    I suggest that you file a mySupport service request asking for this enhancement. (I'm calling it an enhancement rather than a bug fix because the templates might not have been intended necessarily to work in third-party tools, and ModelSim-Altera Edition is really just Mentor's ModelSim as far as this is concerned.)
