17 years ago --- Quote Start --- As vernmid said, ModelSim will use the .vho only if you tell it to... If you are using the NativeLink interface between Quartus and ModelSim to run ModelSim from within Quartus, then Quartus might be telling ModelSim to compile the appropriate library for you. --- Quote End --- I believe NativeLink already tells ModelSim to use the netlist file when you select EDA gate-level simulation on Quartus. I don't think you have to do that manually.
