AEsqu
Contributor
4 years agoDual port RAM Cyclone 5
I'm used to use this RTL code in Synplify to instantiate dual port ram for other FPGA's than the cyclone 5:
module dp_block ( // memory port 1 p1_clk, p1_addr, p1_din, p1_dout, p1_w...
AEsqu
Contributor
4 years agoSynopsys provided me an updated m_altera file for Synplify, that supports the enable in the dual port ram RTL code,
(that was supported for the xilinx mapper).
The code below is now compiling well for the cyclone V.
module dp_block #(parameter DATA_BIT_WIDTH=16, parameter ADDR_BIT_WIDTH=8) ( input [(DATA_BIT_WIDTH-1):0] p1_din, p2_din, input [(ADDR_BIT_WIDTH-1):0] p1_addr, p2_addr, input p1_we, p2_we, p1_clk, p1_re, p1_ena, p2_clk, p2_re, p2_ena, output reg [(DATA_BIT_WIDTH-1):0] p1_dout, p2_dout )/*synthesis syn_ramstyle="no_rw_check"*/; // Declare the RAM variable reg [DATA_BIT_WIDTH-1:0] ram[2**ADDR_BIT_WIDTH-1:0]; always @ (posedge p1_clk) begin if (p1_ena) begin if (p1_we) begin ram[p1_addr] <= p1_din; p1_dout <= p1_din; end else begin p1_dout <= ram[p1_addr]; end end end always @ (posedge p2_clk) begin if (p2_ena) begin if (p2_we) begin ram[p2_addr] <= p2_din; p2_dout <= p2_din; end else begin p2_dout <= ram[p2_addr]; end end end endmodule
