16 years ago
DTW: Can I Save (or Create) a Custom Memory Timing file?
Hi
I am designing a controller for an SRIO peripheral which uses a QDR2 interface. Obviously this is not one of the standard SRAMs provided by DTW, which means I have to manually enter the full set of timing specs when I change my source.
Is there a way to create a custom "memory" in the <variation_name>_qdr_settings.txt file?
Alternatively, can I save just the memory timings from the .dwz file, and import just them after the settings.txt file?
Or is there another solution?
Chris
