18 years ago
DSPbuilder 7.2 and Matlab 2007b
Hi folks,
I am running Quartus 7.2, Megacore Library 7.2 and DSP Builder 7.2. Matlab is 2007b.
I'm trying to walk through the "singen" example. Everything works fine unitl I try to generate HDL. The model simulates in simulink and I get the expected waveforms. But when I bring up the DSP Builder dialog and hit "compile" I get:
Info: Generating HDL
Info: Analyzing Simulink model
Info: Analysis was successful
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 7.2 Build 151 09/26/2007 SJ Full Version
... BLAH BLAH BLAH ...
Info: Processing started: Thu Nov 29 18:29:25 2007
Info: Command: quartus_map singen
Error: IP Generator Error: Entity 'alt_dspbuilder_clock' (Version latest) not found in librarian.
Info: Found 1 design units, including 1 entities, in source file ../singen.mdl
Info: Found entity 1: singen_Interface
Error: Top-level design entity "singen" is undefined
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Info: Allocated 802 megabytes of memory during processing
Error: Processing ended: Thu Nov 29 18:29:29 2007
Error: Elapsed time: 00:00:04
Error: Error during compilation: Synthesis failed
So what gives? Is this due to Matlab R2007b? The DSP Builder manual only shows up to R2007a for compatibility. I'd hate to go back to R2007a just for this.
Any help will be greatly appreciated!
    Hi all,
    In the meantime I could solve the problem on my PC with help from Altera support.
    The ".altera.quartus" directory with the including "ip_cache" folder is not only located in "C:\Documents and Settings\<username>" but also in "%HOME%\" when the HOME environment variable is set. This was the case on my computer then I'm using Cygwin which is also used by Quartus internally. So there are two possible locations for the "ip_cache" folder which you need to check to be sure that there are no files left from other versions.
    schmalisch
    Hi all, I'm working with Vista sp1, matlab r2007b, Quartus 8.0 sp1 DSPbuilder 8.1 the problem has been fixed by deleting ip_cache directory.
    Thanks a lot for this great trick!!!
