17 years agoHi all,
In the meantime I could solve the problem on my PC with help from Altera support. The ".altera.quartus" directory with the including "ip_cache" folder is not only located in "C:\Documents and Settings\<username>" but also in "%HOME%\" when the HOME environment variable is set. This was the case on my computer then I'm using Cygwin which is also used by Quartus internally. So there are two possible locations for the "ip_cache" folder which you need to check to be sure that there are no files left from other versions. Best Regards, schmalisch
