18 years agoDSPbuilder 7.2 and Matlab 2007b
Hi folks,
I am running Quartus 7.2, Megacore Library 7.2 and DSP Builder 7.2. Matlab is 2007b. I'm trying to walk through the "singen" example. Everything works fine unitl I try to generate HDL. The model simulates in simulink and I get the expected waveforms. But when I bring up the DSP Builder dialog and hit "compile" I get: Info: Generating HDL Info: Analyzing Simulink model Info: Analysis was successful Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 7.2 Build 151 09/26/2007 SJ Full Version ... BLAH BLAH BLAH ... Info: Processing started: Thu Nov 29 18:29:25 2007 Info: Command: quartus_map singen Error: IP Generator Error: Entity 'alt_dspbuilder_clock' (Version latest) not found in librarian. Info: Found 1 design units, including 1 entities, in source file ../singen.mdl Info: Found entity 1: singen_Interface Error: Top-level design entity "singen" is undefined Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Info: Allocated 802 megabytes of memory during processing Error: Processing ended: Thu Nov 29 18:29:29 2007 Error: Elapsed time: 00:00:04 Error: Error during compilation: Synthesis failed So what gives? Is this due to Matlab R2007b? The DSP Builder manual only shows up to R2007a for compatibility. I'd hate to go back to R2007a just for this. Any help will be greatly appreciated!
