BIdro's avatar
BIdro
6 years ago
Driver Dedicated Transceiver Pin
Hi, I'm using Quartus Prime Software to program a Cyclone V GT FPGA. I want to drive a differential pair of dedicated transceiver pins ( for example transmit a signal clock or packets without any...
  • Deshi_Intel's avatar
    6 years ago
    HI Bryan,
    Your questions is too high level but let me try my best to answer.
    In general, I advise you to checkout the IP in user guide doc first as different IP solution may have its own design requirement.
    Now to your questions
    1. In the Cyclone V family, is the IP compatible with GT/GX only?
    • The IP can be used for both GT/GX channel.
      • Main difference is the supported data rate
    1. When I use the IP, do I also have to define time constrains?
    • The IP already has its own timing constraint but you still need to constraint your FPGA core own design logic path that interact/connect with the IP block.
    dlim
