MOliv45
6 years agoDRC check CDC-50001 does not work if the given bit is part of a vector?
Summary: If the bit that is missing a synchronizer is part of a vector, the DRC check CDC-50001 FAILS. VHDL code: library IEEE; use IEEE.STD_LOGIC_1164.all; entity cdc is port ( clk1...
MOliv45
6 years agoFor your reference:
VHDL file:
library IEEE;
entity cdc is
port (
clk1 : in std_logic;
clk2 : in std_logic;
rst : in std_logic;
Output_A : out std_logic;
Output_B : out std_logic
end entity;
architecture rtl of cdc is
signal locked : std_logic;
signal locked_reg : std_logic;
signal clk1_pll : std_logic;
component pll is
port (
rst : in std_logic := 'X'; -- reset
refclk : in std_logic := 'X'; -- clk
locked : out std_logic; -- export
outclk_0 : out std_logic -- clk
end component pll;
begin
u0 : component pll
port map (
rst => rst, -- reset.reset
refclk => clk1, -- refclk.clk
locked => locked, -- locked.export
outclk_0 => clk1_pll -- outclk0.clk
process (clk1_pll) is
begin
if rising_edge(clk1_pll) then
locked_reg <= locked;
end if;
end process;
process (clk2) is
begin
if rising_edge(clk2) then
Output_A <= locked;
Output_B <= locked_reg;
end if;
end process;
end architecture;SDC file:
# Create Clock
create_clock -name {clk2} -period 10.000 -waveform { 0.000 5.000 } [get_ports {clk2}]
create_clock -name {clk1} -period 10.000 -waveform { 0.000 5.000 } [get_ports {clk1}]
# Create Generated Clock
create_generated_clock -name {u0|iopll_0|outclk0} -source [get_pins {u0|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst|refclk[0]}] -duty_cycle 50/1 -multiply_by 6 -divide_by 6 -master_clock {clk1} [get_pins {u0|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst|outclk[0]}]
# Set Clock Latency
# Set Clock Uncertainty
set_clock_uncertainty -rise_from [get_clocks {clk1}] -rise_to [get_clocks {clk1}] 0.030
set_clock_uncertainty -rise_from [get_clocks {clk1}] -fall_to [get_clocks {clk1}] 0.030
set_clock_uncertainty -fall_from [get_clocks {clk1}] -rise_to [get_clocks {clk1}] 0.030
set_clock_uncertainty -fall_from [get_clocks {clk1}] -fall_to [get_clocks {clk1}] 0.030
set_clock_uncertainty -rise_from [get_clocks {clk2}] -rise_to [get_clocks {clk2}] 0.030
set_clock_uncertainty -rise_from [get_clocks {clk2}] -fall_to [get_clocks {clk2}] 0.030
set_clock_uncertainty -fall_from [get_clocks {clk2}] -rise_to [get_clocks {clk2}] 0.030
set_clock_uncertainty -fall_from [get_clocks {clk2}] -fall_to [get_clocks {clk2}] 0.030
# Set Input Delay
# Set Output Delay
# Set Clock Groups
set_clock_groups -asynchronous -group [get_clocks {clk1 u0|iopll_0|outclk0}] -group [get_clocks {clk2}]
