14 years ago
Downloading ELF Process failed in Quartus II 10.1sp1
hi
I build one simple nios project in quartus II 10.1sp1 software, compile my software is ok, i have downloaded the sof file into FPGA via jtag. when i prepare to download the ELF file via nios II IDE run --> debug as --> NIOS II hardware, i meet error always. could somebody help me? thanks a lot.
the error log as follows:
eclipse.buildId=M20090917-0800
java.version=1.6.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product org.eclipse.epp.package.cpp.product -perspective com.altera.sbtgui.ui.cPerspective
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.cpp.product -perspective com.altera.sbtgui.ui.cPerspective
Error
Sat Jun 04 11:35:47 CST 2011
Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, --sidp=0xa018, --id=0x1, --timestamp=1307150667, /cygdrive/e/study/debug_nios/software/debug/debug.elf] return code: 4, 'other error'
    HI also have this problem, can anyone help or did you find a solution?
    Which board are you using and what's the cpu frequency? Can you get the system ID from the board using nios II?
    Maybe the frequency is too high, or sdram/sram is not configured properly.
    If you are using external EPCS Flash, try creating a batch file using notepad with the lines between the start and end comments. Do not include the start and end comments. Then using notepad create a Run_Nios_bashrc file with no extension using the lines between the start and end comments. Do not include the start and end comments.
    Put all files in a temporary folder:
    YOUR_BATCH_FILE.BAT
    YOUR_ELF_FILENAME.ELF,
    YOUR_SOF_FILENAME.SOF,
    YOUR_FLASH_FILENAME.FLASH
    file epcs_flash_controller_0.flash
    Run_Nios_bashrc
    You may have to change the base address in the Run_Nios_bashrc per your app
    You probably will also have to create the system variable:
    Step1: Go to Control Panel
    Step2: Go to System
    Step3: Go to the Advanced System Properties
    Step4: Go to the Advanced Tab
    Step5: Go to Environment Variables
    Step6: Press the "New" button
    Step7: Enter the Variable Name and Value below:
    Variable Name: SOPC_KIT_NIOS2
    Variable Value: C:\Altera\10.1sp1\nios2eds (your path may be different)
    Lastly, Double click the batch file.
    ******************batch file start*****************
    @echo off
    @ set SOPC_BUILDER_PATH=%SOPC_KIT_NIOS2%+%SOPC_BUILDER_PATH%
    @ %QUARTUS_ROOTDIR%\bin\quartus_pgm -m jtag -c USB-Blaster[USB-0] -o "p;YOUR_SOF_FILENAME.sof"
    pause
    @ %QUARTUS_ROOTDIR%\bin\cygwin\bin\bash.exe --rcfile Run_Nios_bashrc
    pause
    @echo on
    ******************batch file end*****************
    ******************Run_Nios_bashrc file start*******
    . $QUARTUS_ROOTDIR/sopc_builder/bin/nios_bash
    alias nb=nios2-build
    alias nios-build=nios2-build
    alias nr=nios2-run
    alias nios-run=nios2-run
    alias nd=nios2-debug
    alias nios-debug=nios2-debug
    alias nc=nios2-console
    alias nios-console=nios2-console
    nios2-flash-programmer --epcs --base=0x00609800 -c USB-Blaster [USB-0] --instance=0 YOUR_FLASH_FILENAME.flash
    nios2-flash-programmer --epcs --base=0x00609800 -c USB-Blaster [USB-0] --instance=0 epcs_flash_controller_0.flash
    # nios2-download YOUR_ELF_FILENAME.elf -c USB-Blaster[USB-0] -g -r
    nios2-terminal -c USB-Blaster[USB-0]
    exit
    ******************Run_Nios_bashrc file end*******
    If you just want to download the ELF to the FPGA, try creating a batch file using notepad with the lines between the start and end comments. Do not include the start and end comments. Then using notepad create a elf_downloader file with no extension using the lines between the start and end comments. Do not include the start and end comments.
    YOUR_BATCH_FILE.BAT
    elf_downloader
    Step2: Go to System
    @echo off
    pause
    @ %QUARTUS_ROOTDIR%\bin\cygwin\bin\bash.exe --rcfile elf_downloader
    pause
    @echo on
    ******************elf_downloader file start*******
    alias nr=nios2-run
    nios2-download -c USB-Blaster [USB-0] YOUR_ELF_FILENAME.elf -g
    nios2-terminal -c USB-Blaster [USB-0]
    exit
    ******************elf_downloader file end*******
