15 years agodown-counter with CARRY_SUM-primitives
Hi all,
Since about 3 days I'm trying to implement a down-counter that uses the carry-chain. Reason is, [EDIT : did a mistake, no reason anymore, I just want to know] Device is Cyclone_II, Software is Quartus 7.2sp3 I'm able to implement an up-counter where the carry-chain is utilized, but as soon a I change the carry logic to make it a down-counter, the compiler ignores all of the CARRY-buffers! the only difference is a simple NOT (see below). As far as I understood, the LEs in my case work in arithmetic-mode where the LUT is split into two 3-input LUTs, one for the respective bit of the couter and one for the carry-logic. So I don't get what the problem with this simple NOT is, since the LUT should be able to implement any arbitrary 3-input function. Here are the code-snippets : (In reality, the counters are 32-bits wide, but I'm showing only the first 3 bits here) [comments in square-brackets are not part of the code] ARCHITECTURE cntr_dwn32_sLd_aClr_ena_arch of cntr_dwn32_sLd_aClr_ena IS SIGNAL cntComb : STD_LOGIC_VECTOR (31 downto 0); SIGNAL cntReg : STD_LOGIC_VECTOR (31 downto 0); SIGNAL cntSout : STD_LOGIC_VECTOR (31 downto 0); SIGNAL carryIn : STD_LOGIC_VECTOR (32 downto 1); SIGNAL carryOut : STD_LOGIC_VECTOR (31 downto 0); BEGIN q <= cntSout; [1.) up-counter, this one works] carryOut(0) <= cntReg(0); carryOut(1) <= cntReg(1) AND carryIn(1); carryOut(2) <= cntReg(2) AND carryIn(2); [...] [2.) down-counter, this one works NOT] carryOut(0) <= NOT(cntReg(0)); carryOut(1) <= NOT(cntReg(1)) AND carryIn(1); carryOut(2) <= NOT(cntReg(2)) AND carryIn(2); [...] carr_00_01 : CARRY_SUM PORT MAP (cin => carryOut(0), cout => carryIn(1), sin => cntReg(0), sout => cntSout(0)); carr_01_02 : CARRY_SUM PORT MAP (cin => carryOut(1), cout => carryIn(2), sin => cntReg(1), sout => cntSout(1)); carr_02_03 : CARRY_SUM PORT MAP (cin => carryOut(2), cout => carryIn(3), sin => cntReg(2), sout => cntSout(2)); [...] cntComb (0) <= NOT(cntReg(0)); cntComb (1) <= cntReg(1) XOR carryIn(1); cntComb (2) <= cntReg(2) XOR carryIn(2); [...] reg00 : DFFEAS PORT MAP (d => cntComb(0), clk => clck, clrn => aClr, prn => '1', ena => ena, asdata => ldVal(0), aload => '0', sclr => '0', sload => sLd, q => cntReg(0)); reg01 : DFFEAS PORT MAP (d => cntComb(1), clk => clck, clrn => aClr, prn => '1', ena => ena, asdata => ldVal(1), aload => '0', sclr => '0', sload => sLd, q => cntReg(1)); reg02 : DFFEAS PORT MAP (d => cntComb(2), clk => clck, clrn => aClr, prn => '1', ena => ena, asdata => ldVal(2), aload => '0', sclr => '0', sload => sLd, q => cntReg(2)); [...] END cntr_dwn32_sLd_aClr_ena_arch; Does anyone have an Idea ? Attached you can find the whole vhdl-file. Ah and I'm using quartus 7.2sp3. Maybe this old Version has a Bug ? Could not find a revision-history of the changes made since then. But I didn't want to install the actual 10GB-bloat. P.S.:The LPM-Megafunction is able to implement uo- and down-counters with enable, async.-clear and syncLoad that utilize the carry-chain, so physically it is possible. Thanks for your help Dieter
