15 years agoHi snaarman,
do you use a custom board or an Altera Development Kit?? I ask you this because I had similar problem with the PLL in mine custom board and the problem was in the power supply. At the beginning of the project I used only one PLL and all worked fine, I discovered the problem when I added a second PLL. When the second one locked the clocks signal the first one lost the lock signal. I solve the problem modifying the clock frequencies of the second PLL to fit in the first one because, in my case, to change the power supply became too much expensive. I hope that this post can help you.
