HongLiang
3 years agoDoes the Agliex F support Display port IP ?
we Try to build DP1.4 on the Agliex-F
but we can not find the example from the IP
Does the Agilex-F support the Display Port IP ?
but we can find the design in the Agilex-I.
but ...
ZH_Intel
3 years agoHi Liang Hong,
Thank you for your reply.
I have checked and generated a design example from my end and I do not observe any error in compilation.
Allow me to share with you my design for you to test from your end.
Q1. Did you change any setting in the Design example?
Q2. Do you mind sharing the steps/procedure that you use to generate the design example?
Thank you.
ZulsyafiqH_Intel
