HongLiang
3 years agoDoes the Agliex F support Display port IP ?
we Try to build DP1.4 on the Agliex-F
but we can not find the example from the IP
Does the Agilex-F support the Display Port IP ?
but we can find the design in the Agilex-I.
but ...
ZH_Intel
3 years agoHi Liang Hong,
Thank you for your feedback.
As mentioned for DisplayPort SST Parallel Loopback with AXIS Video Interface, please make sure you change the
"Enable Active Video Data Protocols" parameter to "AXIS-VVP Full" for both DisplayPort Sink and Source in the IP tab to be able to view the example design.
IP Parameter editor screenshot(1)
IP Parameter editor screenshot(2), (Scroll down the IP tab, you can find settings for Sink)
Once you change both Source and Sink "Enable Active Video Data Protocols" parameter to "AXIS-VVP Full", you will be able to see as below:
Design Example Tab
Hope this answers your question.
Thank you.
ZulsyafiqH_Intel
