Does QPP(Quartus Prime Pro) hide or disable engineering change manager(ECO) ?
Hello guys, I found that I can't fine ECO in Quartus Prime Pro. Does QPP hide or disable ECO fucntion? My QPP version is 22.4.
As following image shows, I can't find "edit connetion" menu option in resource property.
- SyafieqS
Hi
I believe the reason is due to ECO limitation which you cannot use ECO commands to modify/edit dedicated connections. You may refer to link below for details.
- MinzhiWang
Hello SyafieqS,
Thanks for you reply me. Because I can't reply any thread in Intel forum long time term, you may lose my info in my several posts. However, I found I can reply now. It's wondful for us.
As your link shows, it seems that lower end devcies don't support ECO function in new QPP version. But the high end devcies can support ECO function in new QPP version. I also found that the standard Quartus Prime version can support ECO for Max 10 devcies.
- SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
