Altera_ForumHonored Contributor13 years agodistance measuring by encoder I bought an encoder which generate square pulses sig. i have to stop the engine if arrived to a required distance. i know that the wheel diameter is 7cm. and the distance is pi*diameter a...Show More
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
