10 years ago
$display in synthesized SystemVerilog module
I wish generate assertion info or error and write code:
generate
    if ((WIDTH != 8) && (WIDTH != 14))
        $("Error in f_AmplCpx : parameter WIDTH is incorrect, found %d, should be 8 or 14", WIDTH);
endgenerate
and I've got error:
Error (10170): Verilog HDL syntax error at f_AmplCpx.sv near text: "$fatal";  expecting ";". Check for and fix any syntax errors that appear immediately before or at the specified keyword.
Using $display, Assert gives the same result.
How can I check parameters in synthesized code?
    $fatal only works in SystemVerilog. Do oyu have that enabled? It's possible that Altera does not support this yet.
    Yes, if you mean
    Settings -> Compiler Settings -> Verilog HDL Input -> Verilog version -> SystemVerilog
