15 years agoDifferential clock outputs from Cyclone II - How to assign
Is there a way (using Quartus) to output a differential clock from a Cyclone II PLL without getting the "Warning: ... Use PLL dedicated clock outputs to ensure jitter performance" message?
I have assigned the two pins for output to the adjacent PLLn_OUTp and PLLn_OUTn pins. Connecting these pins to the PLL "c0" output, with an inverter on one, results in the usual warning for the inverted pin. Examining the floorplan shows that the inverted signal is routed clear across the chip, and then back. The ALTIOBUF_OUT megafunction is grayed out in the megawizard (not applicable to Cyclone II?). ALTOUTBUF_DIFF is not grayed out, but generates an error (not allowed for this device type). There ought to be a way.... Thanks! Carl
