15 years agoThanks for the responses:
josyb: Where can I find the ddr_out function/block/primitive ? fvm: I eventually found a more complete reply from you in another thread. "Select a differential pin pair and assign a differential I/O standard to the positive pin in the Pin Planner or Assignment Editor. the negative pin is assigned by quartus automaticly." - That did the trick! Carl
