kikoss
2 years agoDifferential CLK input handle
Hello I have a a differential clk come in to FPGA agilex7 F series Want to use it as a single clk to the design Iam using quartus 24 .1 pro Which good practice is recommended ? i see on a d...
- 2 years agoHi,
yes. Same procedure for other differential in- and outputs.
kikoss
2 years agoHello
OK if i understand you correctly
- you declare 1 port CLK on top level RTL module - let say FCO_CLK (even if its differential from the ADC)
- use this port on the RTL , for PLL input etc..
- assign FCO_CLK only to P leg on assignment editor (and not assigning at all N leg)
- let the fitter do the job for N leg
Thats rigth ?
THX
- FvM2 years ago
