Difference in SystemVerilog-2005 HDL simulation behavior between Quartus Prime and ModelSim
I see the same message when I compile the design in the Lite edition. This is due to the limited language support in the Lite edition as mentioned in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
I tried to compile the design in the Pro edition, the software did not issue this message during compilation. You may consider to upgrade the software to Pro edition
KhaiY
- HypeInst6 years ago
Intel claims that Quartus Prime Lite supports SystemVerilog-2005. Quartus Prime Pro supports SystemVerilog-2005, SystemVerilog-2009, and SystemVerilog-2012. This information is contained in the "Design Compilation" User Guides for the softwares.
The "iff" gated clock feature of the always@ block is supported by SystemVerilog-2005.
Quartus Prime Pro doesn't support the FPGA device (Cyclone V) that I am targeting, so an upgrade to Quartus Prime Pro isn't a feasible solution.
