13 years ago
Difference between unisgned(a,b) and to_unsigned(a,b)?
Hey guys,
I am a newbie to FPGA programming and VHDL. I just know the basics. I was wondering if someone could tell me the difference between:
    --- Quote Start ---
    --- Quote End ---
    Your first statement is not correct VHDL.
    They are both type conversion procedures. Here's a couple of examples
    -- A standard-logic vector, where bits mean anything
    signal slv : std_logic_vector(7 downto 0) := X"0F";
    -- An unsigned integer, where bits mean positive numbers, eg., 0->255
    signal u : unsigned(7 downto 0) := X"0F";
    -- Conversion of std_logic_vector to unsigned
    u <= unsigned(slv);
    -- Conversion of unsigned to std_logic_vector
    slv <= std_logic_vector(u);
    -- Conversion of an integer to unsigned of width 8-bits
    u <= to_unsigned(123, 8);
    -- Conversion of an integer to std_logic_vector
    slv <= std_logic_vector(to_unsigned(123, 8));
    Cheers,
    Dave
    unsigned(a) - note: not (a,b) - is a type conversion of a similar type a (ie. another array of std_logic, like signed or std_logic_vector.
    to_unsigned(a,b) converts an integer a to an unsigned type with length b.
    Could you please explain this line of code:
    constant ADR_CTRL : unsigned(ADDRESS_WIDTH - 1 downto 0) := to_unsigned(CTRL_OFF, ADDRESS_WIDTH);
    its just a constant with the value CTRL_OFF, with the width ADDRESS_WIDTH. It is an unsigned number
